tw33ki
May 18, 2022, 11:27am
1
i’ve installed invoice ninja v5 in self hosted vm. For some reason i got some problems:
E-Mails wont work:
i changed my .env file.
MAIL_MAILER="smtp"
MAIL_HOST="sslout.df.eu"
MAIL_PORT="587" <-- also tried with 465.
MAIL_USERNAME="info@xxxxxxx.de"
MAIL_PASSWORD="xxxxxxx"
MAIL_ENCRYPTION="tls"
MAIL_FROM_ADDRESS="info@xxxxxxx.de"
MAIL_FROM_NAME="Vertrieb"
And i am sure that my mail settings are fine.
an end via tinker (?) is also functionally:
timo@vertrieb:/usr/share/nginx/invoiceninja$ php artisan tinker
Psy Shell v0.11.2 (PHP 7.4.3 — cli) by Justin Hileman
>>> \Mail::raw('hello world', function($message) {
... $message->subject('Testing email')->to('tm@xxxxx.de');
=> null
i also received this test mail from tinker(?).
But when i send an invoice out of invoice ninja, i am not receiving the e-mail. Also there are no new logs in storage/logs/laravel.log (despite of activating API_DEBUG=TRUE)
(also i was searching for a “test e-mail-button” like during the setup → is there an option to test e-mails from invoiceninja page?
Aktivities per Invoice arent loading. The Stuck here:
No new system-log-entries are beeing generated, for this customer i tried to send the invoice:
(Last try: today, 18. Mai 2022)
No new entries in storage/logs/laravel.log except of:
[2022-05-16 06:00:01] production.INFO: Performing Autobilling 2022-05-16 06:00:01
[2022-05-17 06:00:02] production.INFO: Performing Autobilling 2022-05-17 06:00:02
[2022-05-18 06:00:01] production.INFO: Performing Autobilling 2022-05-18 06:00:01
(so looks like crontab ist running)
I tried already:
chmod 777 /usr/share/nginx/invoiceninja -R (my inovice ninja webroot)
chown www-data /usr/share/nginx/invoiceninja -R
chgrp www-data /usr/share/nginx/invoiceninja -R
As root:
php artisan optmize
Does anyone know how to debug this stuff? Or does someone know how to solve that problems?
May 18, 2022, 11:40am
3
Let’s start with emails, what is QUEUE_CONNECTION set to in the .env? Maybe the queue is enabled but not running. Changing to sync
will make it run immediately when sent.
tw33ki
May 18, 2022, 12:14pm
4
Oh woooow! Did the trick
timo@vertrieb:/usr/share/nginx/invoiceninja$ cat .env | grep QUE
#QUEUE_CONNECTION=redis
QUEUE_CONNECTION=sync
I had redis as option here. Ist this a wrong setting?
May 18, 2022, 12:26pm
5
Glad to hear it’s working!
I’m not sure why the value would be set to redis, how did you install the app?
cc @david
Thank you very much
I followed up this tutorial:
Install Invoice Ninja v5 on Ubuntu 20.04
If you are self-hosting, installing on Ubuntu is the best possible method, and highly suggested. Running Ubuntu as a host allows you to install with the least amount of effort, fewer dependencies, and auto-update the application through the admin portal user interface. The ‘invoiceninja.zip’ package that is compiled by the Invoice NInja team every release has many dependency packages bundled into it, but it is only compatible with Ubuntu, and maybe oth…
After that i had that feeling that it’s behavior is realy slow. Then i decided to install redis cache (i think i did some failure here). I used some tutorial from google, but cant find it again atm.
Do u have some tipps for me, why my system-log (at customers 2-3 ?) isnt working correct?
To clarify, the systems logs load for some clients but not others?
Are there any errors in the browser console or storagel/logs?
I dont know what happend meanwhile, but my customer logs are loading now.
Thanks for ur help
But maybe, u can help me with some update problem i got today. I tried to update through the webgui. After that i got this error:
Do u know this one maybe?
May 26, 2022, 7:02am
10
It may help to increase the PHP memory limit.
tw33ki
June 12, 2022, 9:43pm
11
Thank you. That one did the trick
