Self Hosted - v4.5.14
Hello I’m having a problem with the invoice link when I click the “view invoice” link in the email or click the “view in portal” button in the invoice section I get the same error:
No Results Found
The page you requested could not be found. Try refining your search, or use the navigation above to locate the post.
I have a wordpress site. I have the iframe on a wordpress page (also tried just in a basic html) same issue. I’ve tried adjusting the link under the client portal setting, I’ve adjusted the .env to every possible location I could think of. Not sure what else to try. Any suggestions would be very appreciated.
If there’s a relevant log I can access let me know where to look if possible. Any other details that would help I can provide not sure if it’s recommended to post the link here?
Thanks!
Few more details:
Install Folder is
mydomain.com/Admin
Link is: https://mydomain.com/client-portal
Website where iframe is: https://mydomain.com/client-portal
When I go directly the the link where the iframe is I get the account login.
When I click the view invoice link as described above I get the no results found error.
