Hi, how do I get rid of “Powered by Invoice Ninja - v4.5.13 | White labeled”. I have purchased white label, but I am still seeing this.
The white label merely removes the Invoice Ninja branding from sent invoices and from the client portal.
So If I create company for client they will see the powered by invoice ninja
How do I become reseller for invoiceninja?
Correct. If you are setting up the application for a client, they will still see the information at the bottom. The white label is for personal use (i.e. sending invoices from your company to a client).
If you want to resell, you’ll need to send them an email. contact@invoiceninja.com
Thanks for the info, appreciate your help
