If I create an invoice using a defined product and I change the pricing or even description. That affects the product and it’s pricing/description.
Is there anyway of having the products pricing/description not change. Sometimes we give certain customers breaks or add description wording. It would be great not having to change it back.
Head into Settings > Products, and un-check “Auto-update products.” That should keep the products as-is unless you manually go into the list and change them from there.
Excellent! Thank you Hillel.
I’m not Hillel, but he is a pretty cool guy.
I’m so sorry for that Titanfail. Hillel usually answers me so I naturally thought he responded back.
Thanks again for your help.
