So just sent my first live invoice with Invoice Ninja, only took 40 minutes
I created a new template on my working computer and tested everything 10-15 times, then I got home and it would just not use the new template. After cleaning the browser cache and running CCleaner i finally got the new template.
Question #1: The web app feels cache heavy, is it possible to make it cache less?
Edit: Browser: Firefox
Then I got XHR errors when sending the invoice, I checked SMTP2GO and the invoice was indeed sent but Invoice Ninja didnāt display it as sent.
Question #2: Is there any way to to set SMTP sending timeout? Sometimes a SMTP server may take a couple of seconds before responding.
Question #3: Why is tabbing not working in Firefox? It tabs to the Back and forward button and the URL-field but you canāt tab between inputs?
Qustion #4: If running Firefox with the console open it spits out āError in parsing value for property āfontā. Declaration droppedā, is this normal?
Havenāt tried chrome, will try it tomorrow then try the desktop app.
Here are two request that takes a bit of time
/api/v1/refresh?current_company=true&updated_at=1631557393&first_load=true = 626ms
/storage/IltRDpr79RDMJJvB3jeDMB4xUsuxpfmkhWhIXKMhjdE1VXpdZt9mpCK2V3vU1Hbk/cwnvvc9cqv6KyP31834xEoeeKzCxBoF3d7bubVgp.png (logo) = 90ms
I added 300 seconds to the timeout in config/mail.php since my nginx is configured to timeout after 300 seconds. Lets see if it helps
Nope, Iāve cleared the cache a couple of times, it works in Brave and Edge.
Its in Swedish but it spams the same messages when moving the mouse.
Just installed the Windows app and the strangest thing is happening. When starting the app and choosing Self hosted, when I type the email address, after the @ sign the keyboard stops working and I have to restart my computer. Have never seen this before.
Iāve tried 3 times with the same result. I have to test it with my working computer, this is super strange
Edit: Seems to be working on my work computer so maybe there is something wrong with my Windows Store at home.
