Is there a way to print or export an expense to a PDF without converting it to an invoice?
Thank you.
Thank you.
Maybe you could export it to CSV using the report and then convert it PDF?
Hi @hillel
Thanks for the reply.
Yeah, I could do that for all expenses, but i was wondering if there is a way to export a single expense to a PDF (or other formats). The idea is to print out the expense to be with the invoice for example for filing.
FYI, I did not receive an email about your reply even though I have it marked as Watched.
It isn’t currently supported but feel free to create an issue to request the feature:
