Hi…In my setup all was working fine so far…But suddenly while generating invoice pdf it shows error as like screen shot.!
Was anything changed?
The info here may help:
https://invoiceninja.github.io/docs/self-host-troubleshooting/#pdf-conversion-issues
Hi…Nothing changed …All was working fine just before two invoices…After that what ever created shows this error…I’m using phantom pdf cloud with free registered key for pdf conversion…Not the demo.
I had refresh the URL…But that doesn’t shows anything related to this error.!!
Are there any errors in the logs? The link above explains where to check.
No errors on /storage/laravel log
Most likely using Phantom JS with default API key
You’ll want to register for a API key with Phantom JS as per docs.
