Invoice Ninja: v5.1.8
PHP version: v8.0.2
I appreciate that Arch is not a “supported” distro but it makes for a brilliant OS on a VPS as it is small, quick and, being a rolling release OS, never requires a re-build of the VPS every time there is a major new OS update (like Ubuntu, CentOS etc). My company is moving all our servers to Arch for this reason and because we all use Arch on our desktops in the office. InvoiceNinja is the only Laravelle app I’m struggling to migrate.
Once I get this working I propose to create a package and submit it to Arch AUR (the current one is way out of date and doesn’t work). So all help to get this resolved gratefully received!
I have a working version of 4.5.3 on our Ubuntu VPS but it is being decommissioned within the next 4 weeks so I’m on the clock
I’ve installed 5.1.8 on the Arch server and have successfully migrated from our v4 server without any apparent errors. But PDF generation refuses to work - the setup was OK and the test PDF produced, and I’ve manually run snappdf from the app folder and generated a PDF of “Hello World” but inside the app when trying to either create and invoice or create a new invoice style I get 500 server errors with
production.ERROR: Required parameter $field follows optional parameter $custom_fields {“userId”:1,“exception”:"[object] (ErrorException(code: 0): Required parameter $field follows optional parameter $custom_fields at /srv/http/hosts/invoiceninja/app/Utils/Helpers.php:52)
as the error message.
As a check, I dropped all the tables and rebuilt them using artisan. I then used the dummy company (without migrating our live data) to rule out something being wonky with the migration process. Same result and error message.
Any ideas what I can try to get this to work? I’d prefer not to downgrade PHP as v8 is required for another app.
TIA
