I have invoice ninja running locally on my synology using docker NAS just for my personal use of generating invoices
The issue I am running into is on viewing pdf or generating live preview I get gateway 504 timeout error after a while of it trying to load I can’t figure out what I am doing wrong I purchased white label so I could use hosted_ninja thinking that would resolve issue but still can’t get pdf’s to generate
Anyone have any ideas?
June 30, 2022, 2:10pm
Does the server have network access?
@david any thoughts?
Excuse my lack of knowledge here but how would I double check this as far as I am aware yes as I cloned the git onto it and ran all the docker compose and license the white label so don’t think any of that would happen without network access
One thing I have noticed in log file under docker files/docker/app/storage
Was that it was mentioning about unable to find invoice I don’t have the file to hand but can add the log later. But very strange as everything else works
June 30, 2022, 2:59pm
4
If you can post details from the logs in storage/logs it may help
It turns out I have copy of the log on my email from the this morning:
[2022-06-30 08:15:59] local.ERROR: Server error: POST https://pdf.invoicing.co/api/
resulted in a 504 Gateway Timeout
response:
504 Gateway Time-out
<cente (truncated...)
{"userId":1,"exception":"[object] (GuzzleHttp\\Exception\\ServerException(code: 504): Server error: `POST https://pdf.invoicing.co/api/` resulted in a `504 Gateway Timeout` response:
run()
#5 /var/www/app/vendor/guzzlehttp/promises/src/Promise.php(224): GuzzleHttp\\Promise\\Promise->invokeWaitFn()
#6 /var/www/app/vendor/guzzlehttp/promises/src/Promise.php(269): GuzzleHttp\\Promise\\Promise->waitIfPending()
#7 /var/www/app/vendor/guzzlehttp/promises/src/Promise.php(226): GuzzleHttp\\Promise\\Promise->invokeWaitList()
#8 /var/www/app/vendor/guzzlehttp/promises/src/Promise.php(62): GuzzleHttp\\Promise\\Promise->waitIfPending()
#9 /var/www/app/vendor/guzzlehttp/guzzle/src/Client.php(187): GuzzleHttp\\Promise\\Promise->wait()
#10 /var/www/app/vendor/guzzlehttp/guzzle/src/ClientTrait.php(95): GuzzleHttp\\Client->request()
#11 /var/www/app/app/Utils/HostedPDF/NinjaPdf.php(31): GuzzleHttp\\Client->post()
#12 /var/www/app/app/Http/Controllers/PreviewController.php(375): App\\Utils\\HostedPDF\\NinjaPdf->build()
#13 /var/www/app/app/Http/Controllers/PreviewController.php(180): App\\Http\\Controllers\\PreviewController->blankEntity()
#14 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Controller.php(54): App\\Http\\Controllers\\PreviewController->show()
#15 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(45): Illuminate\\Routing\\Controller->callAction()
#16 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Route.php(262): Illuminate\\Routing\\ControllerDispatcher->dispatch()
#17 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Route.php(205): Illuminate\\Routing\\Route->runController()
#18 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Router.php(721): Illuminate\\Routing\\Route->run()
#19 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(128): Illuminate\\Routing\\Router->Illuminate\\Routing\\{closure}()
#20 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(127): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#21 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(63): Illuminate\\Routing\\Middleware\\ThrottleRequests->handleRequest()
#22 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\\Routing\\Middleware\\ThrottleRequests->handle()
#23 /var/www/app/app/Http/Middleware/QueryLogging.php(39): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#24 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\\Http\\Middleware\\QueryLogging->handle()
#25 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(50): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#26 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\\Routing\\Middleware\\SubstituteBindings->handle()
#27 /var/www/app/app/Http/Middleware/Locale.php(49): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#28 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\\Http\\Middleware\\Locale->handle()
#29 /var/www/app/app/Http/Middleware/TokenAuth.php(99): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#30 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\\Http\\Middleware\\TokenAuth->handle()
#31 /var/www/app/app/Http/Middleware/SetDb.php(41): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#32 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\\Http\\Middleware\\SetDb->handle()
#33 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#34 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Router.php(723): Illuminate\\Pipeline\\Pipeline->then()
#35 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Router.php(698): Illuminate\\Routing\\Router->runRouteWithinStack()
#36 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Router.php(662): Illuminate\\Routing\\Router->runRoute()
#37 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Router.php(651): Illuminate\\Routing\\Router->dispatchToRoute()
#38 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(167): Illuminate\\Routing\\Router->dispatch()
#39 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(128): Illuminate\\Foundation\\Http\\Kernel->Illuminate\\Foundation\\Http\\{closure}()
#40 /var/www/app/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestIpMiddleware.php(45): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#41 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Sentry\\Laravel\\Http\\SetRequestIpMiddleware->handle()
#42 /var/www/app/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestMiddleware.php(42): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#43 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Sentry\\Laravel\\Http\\SetRequestMiddleware->handle()
#44 /var/www/app/vendor/livewire/livewire/src/DisableBrowserCache.php(19): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#45 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Livewire\\DisableBrowserCache->handle()
#46 /var/www/app/app/Http/Middleware/Cors.php(25): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#47 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\\Http\\Middleware\\Cors->handle()
#48 /var/www/app/vendor/fideloper/proxy/src/TrustProxies.php(57): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#49 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Fideloper\\Proxy\\TrustProxies->handle()
#50 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#51 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ConvertEmptyStringsToNull.php(31): Illuminate\\Foundation\\Http\\Middleware\\TransformsRequest->handle()
#52 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\\Foundation\\Http\\Middleware\\ConvertEmptyStringsToNull->handle()
#53 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#54 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TrimStrings.php(40): Illuminate\\Foundation\\Http\\Middleware\\TransformsRequest->handle()
#55 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\\Foundation\\Http\\Middleware\\TrimStrings->handle()
#56 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ValidatePostSize.php(27): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#57 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\\Foundation\\Http\\Middleware\\ValidatePostSize->handle()
#58 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/PreventRequestsDuringMaintenance.php(86): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#59 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\\Foundation\\Http\\Middleware\\PreventRequestsDuringMaintenance->handle()
#60 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#61 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(142): Illuminate\\Pipeline\\Pipeline->then()
#62 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(111): Illuminate\\Foundation\\Http\\Kernel->sendRequestThroughRouter()
#63 /var/www/app/public/index.php(57): Illuminate\\Foundation\\Http\\Kernel->handle()
#64 {main}
[2022-06-30 08:38:17] local.ERROR: Server error: `POST https://pdf.invoicing.co/api/` resulted in a `504 Gateway Timeout` response:
run()
#64 {main}
June 30, 2022, 3:12pm
6
Thanks, @david any thoughts?
david
June 30, 2022, 11:18pm
7
@Reece157
That is unusual. Can you confirm the issue is still persisting for you?
I do know that on the 30th we had an even which triggered scrubbing of DDoS traffic on our hosted PDF generator but our infrastructure was still serving legitimate traffic.
Hi yes this still seems to be an issue for me and it’s driving me nuts as I generally don’t know how to resolve the problem
I have checked again today same issues
does seem some extra info in the chrome console if this is any help in tracking down the issue?
so I have seemed to have gotten all pdf functionality working now. But it generates the invoices etc with the logo missing from it and I cant seem to figure out why any suggestions?
July 4, 2022, 3:48am
11
It may help to add LOCAL_DOWNLOAD=true in the .env file
https://invoiceninja.github.io/docs/env-variables/
Yes I have this included in my current env file and issue still seems to persist unfortunately
seems to only show the logo where preview html toggle is switched but in any of the pdf views its broken
just to add I can get to the logo image from the link shown up in the console http://domain :port/storage/hash.png so I assume from that the URL is resolvable as seen that alot in the forum
david
July 4, 2022, 10:35pm
16
@Reece157
I believe the issue will be the internal DNS resolution of the domain name on your NAS, if you are able to manually set the domain name in the /etc/hosts file (if it exists on that platform) that should resolve your issue.
@david thanks for response and so would this be the host file on the synology NAS itself or the host file in Config docker folder as the docker config/hosts I have tried placing the IP of nas in their and no luck
super lost now setup dns server on the Synology added record for the domain and pointed it to it on my LAN ip:port of invoice ninja and still the logo shows up broken but shows up everywhere else on the site and by the URL its requesting am I doing something wrong?
david
July 6, 2022, 1:54am
19
Reece157
In the dockerfile there should also be a /etc/hosts file where you’ll need to add the IP, the issue is the container itself cannot resolve your URL
@David so it seems the host file in etc file already has the ip and domain as I had added it Into the extra hosts in the docker compose file and would appear this does the same thing so no idea why this is still not working
