First of all, I wanted to thank you guys for creating such an awesome product. I’ve been using it for a few releases now, and it’s really, really helped my business! So thanks…
Anyway, in the last few releases there has been a bug when entering payments. If you create a payment, scroll down the payment type dropdown, and take a look, you’ll see about 6 at the bottom that display as “texts.payment_type_XXX”.
Furthermore, I was wondering when we might see Stripe support implemented once more?
Only have Paypal Express configured. I had stripe set up a few versions ago, but I attempted an update and it completely broke my installation. It was a disaster and I ended up having to fix a bunch of stuff through the back end. The upgrade was causing foreign key constraint errors from memory, then I was receiving an error regarding one of the libraries associated with stripe if I recall correctly.
I’ll try set it up again now if it’s meant to be working!
