Payment reference variable in Invoice footer
Hi.
I would need to add a footer note.
When paying please enter a payment reference: <Invoice number>. Would need to have that in multiple languages, based on the client language setting.
Is there a way for this?
Thank you
Br,
Dali
One option may be to use a custom dropdown invoice field but you’d have to manually select the value for the client’s language.
Thank you Hillel.
Isn’t that extremely awkward workaround for such a basic feature?
Br,
Dali
Found a solution. Not multi language but it works.
Inside Invoice terms I put.
Payment Referencec: $invoice.invoiceNumber
Br,
Dali
