Payment Link Options Don't Display
When a new user accepts an invitation to join an organisation and enters their details, the ‘Return to Login’ screen does not have the correct branding, and the link takes the user from the self-hosted login screen to the SaaS-hosted login screen.
Is there a fix for this?
@david can you please advise?
I believe you answered this question recently but I can’t find your answer.
If you are using the react application, you’ll want to set the REACT_URL= in your .env file.
Thanks. That fixed the URL. I mounted the dir containing the image and swapped the images over to modify the branding.
