Hello.
Is there any way to edit the text in the initial email for the password field?
We would like to change it to something like this:
Please retain this password for future use: XXXXXXXXX
It isn’t supported in the app but you may be able to manually change the language file
Thanks.
Changing line 272 did work however it also changed the field on the login page. I’m guessing anywhere else the field “password” appears would also be changed.
How about just adding an additional note to the one time password message?
Maybe something like this:
Please retain this password for future use.
Password: XXXXXXXXX
Sorry if this really isn’t possible, I have very little knowledge of coding an app like this. I guess I’m just assuming there is some text somewhere that could be edited.
Thanks again for responding.
I think you’d need to modify the code. Sorry, we aren’t able to provide developer support.
