Open Exchange Setup
Has anyone been successful at setting up Open Exchange with v5 self-hosted?
I found the Currency Conversion section at the bottom of this document: invoiceninja.github.io/self-host-installation.md at v5-rework · invoiceninja/invoiceninja.github.io · GitHub
I’ve registered for an App ID, added it to my .Env file, ran php artisan optimize, but am unsure it’s actually working. I entered an expense in USD that I selected to convert, but there was no conversion rate populated automatically.
How often does Invoice Ninja poll the exchange rates?
Chris
The app should load the rates once a day, it may help to check if the rates are set in the currencies table.
@david do you have any suggestions to debug?
Currencies are populated. Perhaps I tried before the update happened. Thanks for the tip to check this table for data.
You can update the admin portal using the refresh data option on Settings > Device Settings
currencies are updated once a day :slight_smile:
