When opening the website I land on the /setup page.
I’m able to pass everything inside and when continueing it reloads the setup page.
Forcibly going to the url again takes me to an error 500 page.
Hi ,
This command fixed mine: php artisan migrate:fresh --seed. Run it in the sites root directory and itll make all the tables, after run the setup again and it should work!
I also did a completely new install and running into the same problem.
Having to use php artisan migrate:fresh --seed and then getting the error in the Screenshot.
