According to the documentation (https://invoice-ninja.readthedocs.io/en/latest/client_portal.html#settings) the self-hosted version should have an option for Custom Javascript for the portal.
I don’t have that option, just custom CSS. Is custom Javascript no longer an option?
I think the feature may just be on the develop branch of the self host version.
Looks like this didn’t make it into 4.5.13, will it be included in a future update?
Or is there some other place I can drop my JavaScript? I want to add our live chat to the portal.
5
We’re currently focused on v2, we aren’t adding any features to v1.
You should be able to manually add the code you just need to re-add it after updating.
You’d probably want to add it to: resources/views/public/header.blade.php
Thanks, Hillel, that workaround worked a treat and will suffice for now.
Looking forward to 2.0!
