I updated from 3.9.1 to 4.1.4 manually, and thought all was working ok. However, when I try to create or edit an invoice, I get no Line Total. It stays empty for new invoices and on old invoices created before the updrade, the line total remains populated but will not change.
Tried it on Chrome with same result. Strangley, amending invoices works, but creating new ones fails as described, then I can’t amend afer that. Almost as it pdfmake crashes then can’t recover.
I’ve just sent that. The PDF does not render the line total. It will render everything else ok as I change it, even though those console errors/warnings still appear.
Just realised that the quantity field is missing from the interface, so its not able to work out what to render. Not sure why its missing at the moment.
Looks like that solved it. Weird that it disappeared on upgrade.
However it now displays qunatity column on the custom invoice design - when I want just item,desciption, line total (and not quantity). Any idea how I remove it from the pdf but keep it on the interface?
There is a bug currently where if the qty field is hidden the app isn’t automatically setting the qty to 1, this will be fixed in our next minor release.
Saying that - previously the qty field was hidden using the product fields, but still appeared on the interface (not on the PDF). Is this how its intended to appear again after the fix?
Just because the qty field isn’t on the invoice, doesn’t mean it is always 1 - at least not for me.
