I made some changes on a custom name template.
When i select this template and select “update all records” the template is still the old one when opening an existing invoice.
Koen
Koen
Are you resaving the invoice after the design change?
This would be required to regenerate the PDF.
Hi David…
Now i did with one… worked…
Is it possible automatic?.. Opening a few hundres invoices and saving is a hell of a job after making some changes on the template.
I tought update all records will did the job?
Koen
