I’ve been trying to do a migration from v4.5.38 to latest version of v5.
The migration keeps failing.
The email notification says the following.
Undefined index: ninja_tokens
What are the steps for a manual migration?
February 23, 2022, 8:43am
Hi, I tried updating to the 4.5.49.
Now I’m getting a 500 Server error.
The .env file is the same. Just replaced all the old files with the new files except for .env and /storage/documents.
[autoindex:error] Cannot serve directory /home/dcladmin/webapps/app-invoiceninjav4/: No matching DirectoryIndex (index.html,index.php,index.php2,index.php3,index.php4,index.php5) found, and server-generated directory index forbidden by Options directive
February 23, 2022, 12:33pm
5
I’m not sure, you may want to setup a clean v4 install and copy over the .env file and database using mysqldump.
I’m at a loss. I downloaded the 4.5.49 zip file.
Deleted all the other files in the webapp folder.
Uploaded the zip file, unzipped.
Using a subdomain.
Clean database.
Can’t access the install window for Invoice Ninja.
500 server error.
So I copied the .env file over.
Still error.
Uploaded the database from mysql dump.
Still.
Feeling like about to give up. But I need to access my data, clients, invoices, e.t.c.
Is there anyone who can help me? will pay for your time.
htaccess
RewriteEngine On
RewriteRule “^.env” - [F,L]
RewriteRule “^storage” - [F,L]
RewriteRule ^(.well-known)($|/) - [L]
RewriteRule ^(.*)$ public/$1 [L]
February 24, 2022, 6:52am
7
If you see a 500 error there should be more details in storage/logs or the web server error logs
I managed to get into the dashboard
I reset the db password which seems to fix the connection issue.
Now when I click on Settings in the dashboard, it says
Not Found
The requested URL was not found on this server.
February 24, 2022, 8:10am
10
Have you made any changes to the code or is it a clean install?
Clean install.
Okay I uncommented the RewriteRule ^(.*)$ public/$1 [L] in the htaccess file. That seems to have fixed that error of URL not found.
I’m going to try the migration
xoo
February 24, 2022, 11:16am
12
What PHP version are you using?
Using php 7.4
The migration worked. I’m now on v5.
