Hi there,
I have been happily running IN for a couple of years on docker with docker-compose. Unfortunately, when I started using it I knew little about docker so I was pulling this image: image: invoiceninja/invoiceninja without a tag
today I updated and things broke as the latest image as I found out has heavily changed. I then looked into the latest image I had previously pulled without a tag and it said 4.5.17
so I now went back and use image: invoiceninja/invoiceninja:4.5.17 and am getting back my dashboard but still have the following problems:
- in my dashboard:
A new version of Invoice Ninja is available. You’re running v4.5.16, the latest is v4.5.17
this is nonsense, my docker-compose states:
app:
- I also just bought the white label extension and the dashboard still says:
Your white label license has expired, please consider renewing it to help support our project.
Can somebody please explain the way forward so that my IN instance gets to a stable and updated version while staying usable?
I kinda need an upgrade path and how to proceed please.
