Mysteric invoices in Client Dashboard + Mail
Hey,
I’m occuring some strange behaviour with the Client’s Dashboard and mailing.
In the Client’s Dashboard some invoices are shown even if they don’t belong to the client. So Invoice I belongs to Client X but is shown at Client Y in the Dashboard and Client Y gets a mail about Invoice I too. In my admin dashboard everything is fine, so there is no Invoice I with Client Y.
I do have checked in the DB, if I ask for all the invoices with the ID of Client Y the Invoice is not shown, but in the Client’s Dashboard it is…
Are you using invoiceninja.com or are you self hosting?
Self hosted version :slight_smile:
Which version are you running?
I updated today but the problem occurs from the beginning on, 2.6.X
Are you seeing new instances of the problem or just the earlier one?
It’s possible this was a bug which has since been resolved.
You can run the command php artisan ninja:check-data to check the integrity of your data.
Okay, I hoped I solved it by setting up a new instance of Invoice Ninja.
But now the option to add a second company isn’t available anymore? Or where is it located?
If you click your name in the top right you should see a add or manage companies option.
