Multiple tax rates
I am from Quebec, Canada and I need to apply two taxes on an invoice and they need to be show separately.
Is there a way to add two taxes line on an invoice?
Mathieu
I’m sorry, it isn’t currently supported.
One option may be to create a custom invoice charge and manually calculate the second tax.
Same problem here. Will look in the code and see if there’s anything I can do…
Would you accept pull request?
Yes, we’d definitely accept a pull request to add support for multiple tax rates.
That said you should be aware this would be a non-trivial change. Here’a partial pull request for the feature someone created a while back.
https://github.com/invoiceninja/invoiceninja/pull/211
