Multi company Emailing
Hi colleagues,
i want to set up an instance with two (+) companies. Works mostly (have an issue with logo upload on company 2, but ok…
but the biggest issue is: sending emails by .env defined emailadress means that either company1 or company2 is sent by wrong emailadress. It seems as the email in backendconfig is not used for sending.
if i delete the configuration in .env it sends by hello@example.com - also not fine (SPF etc).
How do you handle this?
thanks in advance chirs
Have you seen the info here:
not yet, working. Fine :slight_smile: Thanks!
