Move Company from one instance to another
I have 2 instances of InvoiceNinja.
And I wanted to consolidate them into one.
I wanted to know if there is a way to transfer one company from one instance to another?
One option would be to export/import the data as CSV.
Other than setting up the company profile and settings manually
would that import all the invoices, payments, clients, and details?
It should. You can test it by creating a new blank company, importing the first company using JSON and the second company with CSV.
@david would it be possible to use JSON for the second company?
Thanks for the help!!
I just exported the json of the company backup and uploaded it into the new company on the other server. Everything except the logo and products transferred, so I just manually exported and imported the products as a CSV file and reupload the logo.
