Frustrating but Mollie is not working
Mollie - API version 2 should be used
Multisafepay - you have only the option to activate creditcards in the gateway. Other cards like ideal / kbc are not working.
Edit, see below. That’s the solution
Ok, many thanks for your reply… It didn’t work yet, but found this solution:https://github.com/invoiceninja/invoiceninja/issues/3143
that was working!
