thanks for this great pice of software.
I try to migrate from v4.5.18 to v5.1.70-C51.
On my new v5 instance the cron job is running smoothly and after the migration is starting from v4 the only thing that happens is that a new .zip file is created with a json file in it that i not can manully imported into the v5 instance.
now i got it working and succefully migrated to v5.
Did have to deactive the SSL certificate.
But now v5 wants to activate my migrated company and needs a token?
In v5 the company is de-activated by default so reminders and recurring invoices aren’t sent from both apps. You can activate on Settings > Account Management.
I’m not sure what you referring to about the token, can you please clarify
