I’m curious if anyone is attempting to move from v4 to v5 with different servers. I can’t seem to find much documentation about it, but when I go to Settings → Account Management, I get to the part where it asks me to authenticate - but on clicking ‘Continue’ nothing happens.
I’m sure there’s something I’m missing… but I can’t figure it out. I’m attempting to move from:
my.ciits.co.uk
to
v5.ciits.co.uk
Once it’s complete, I’ll be attempting to update v5 to my - but using the new server.
Any help would be greatly appreciated.
Paul
ben
December 4, 2020, 10:50am
Hey there!
Thanks for reporting this to us. Can you check if there’s anything in v5 logs?
You can find them in storage/logs/laravel.log/
file.
Thanks!
ben:
Just looked on v5 server and there’s nothing in the error log. It’s blank.
Looking at network inspector on the v4, it’s making a POST to /migration/auth where it get a 302. Then there’s a 200 GET to the same URL. Not sure if this helps at all.
ben
December 4, 2020, 2:47pm
4
Can I know the version of Invoice Ninja v4 that is in use? Also, a version of v5 would be nice.
There are updates to 4.22 or so that are improvements to migration, important updates to prepare.
Both servers need resolvable domains. This can be worked around with edit to hosts file if necessary.
Thank you for that. I’ve upgraded it to the latest v4 version.
I attempted the migration but am now showing this error:
Error: Make sure you did proper setup with V5 of Invoice Ninja, before starting migration
So, I’m not sure where to go next. v5 is installed fine and I can login etc without issue. Is there something I’ve obviously missed?
Thanks for your help.
ben
December 5, 2020, 3:20pm
9
Hey @ItsJustPW
I am able to replicate your issue! You could wait us to fix this in upcoming v4 (within a day or two).
Issue is v5 .env file having API_SECRET set to something. If you make it empty:
API_SECRET=
you should be able to pass this screen!
Issue was resolved thanks to the Invoice Ninja Slack channel and speaking to Benjamin. Really, really amazing support from Invoice Ninja.
Thank you!
And yes use 4.23 or latest version
sasax
December 8, 2020, 10:21pm
12
I’m having the same problem. Can you tell us your solution? Thanks friend.
ben
December 10, 2020, 10:50am
13
Hey there,
Issue is that v5 is requiring an API_SECRET to be set. Just open .env file of Invoice Ninja v5 and remove whole line.
After that just run:
php artisan optimize
Sorry for the delay… exactly what Ben is saying - it was because of the API_SECRET which was causing the issue.
sasax
December 10, 2020, 1:05pm
15
How do I edit it in a docker installation?
I remember reading that I could map the .env file to a persistent folder.
ben
December 10, 2020, 2:09pm
16
Here’s how you can do it in Docker.
Navigate to invoiceninja5 directory.
Run this to enter docker container:
docker-compose exec app sh
cd /var/www/app
vi .env
Now find a line with API_SECRET and delete it. Save the file & run this inside the Docker container:
In case you’re not familiar with vi
To open file: vi .env
To write: Press “I”
To save: Press ESC, then “:” and then “wq”
That should save & quit.
sasax
December 12, 2020, 8:00am
17
Thank’u so much. I’ll try and comment.
sasax
December 12, 2020, 11:16pm
18
Hi guys, I have both latest versions v4 and v5. I have tried again to migrate to v5, changing what was commented above. I see the migration files in both locations of the two instances, but nothing else happens. The companies that I have in v4 are created into v5, but empty … without any content. I don’t know what I can be doing wrong. The migration assistant does not give any errors.
I see a new thing at ‘Health Check’ --> Config Cached with a orange triangle.
It’s working
docker-compose exec app php artisan schedule:run >> /dev/null 2>&1
Now i can see the log importing my data.
ben
December 14, 2020, 9:25am
19
Hey there! Great to hear that! Please update us on how it went
sasax
December 17, 2020, 9:30pm
20
[2020-12-17 17:20:41] production.INFO: migrations/2qwjtlzdhwgylsekda9jpeauap7mogkh-2020-12-17-invoiceninja.zip
[2020-12-17 17:25:08] production.INFO: Importing company
[2020-12-17 17:25:09] production.INFO: Importing users
[2020-12-17 17:25:09] production.INFO: Importing payment_terms
[2020-12-17 17:25:09] production.INFO: Importing tax_rates
[2020-12-17 17:25:09] production.INFO: Importing clients
[2020-12-17 17:26:27] production.INFO: Importing vendors
[2020-12-17 17:26:27] production.INFO: Importing projects
[2020-12-17 17:26:28] production.INFO: Importing products
[2020-12-17 17:26:29] production.INFO: Importing credits
[2020-12-17 17:26:32] production.INFO: Importing invoices
[2020-12-17 17:45:50] production.INFO: Importing recurring_invoices
[2020-12-17 17:46:07] production.INFO: Importing quotes
[2020-12-17 17:54:57] production.INFO: Importing payments
[2020-12-17 18:32:18] production.INFO: Importing company_gateways
[2020-12-17 18:32:18] production.INFO: Importing client_gateway_tokens
[2020-12-17 18:32:18] production.INFO: Importing expense_categories
[2020-12-17 18:32:18] production.INFO: Importing task_statuses
[2020-12-17 18:32:18] production.INFO: in task statuses
[2020-12-17 18:32:19] production.INFO: finished task statuses
[2020-12-17 18:32:19] production.INFO: Importing expenses
[2020-12-17 18:32:19] production.INFO: Importing tasks
[2020-12-17 18:32:19] production.INFO: Missing resource key: task_statuses_4
[2020-12-17 18:32:20] production.ERROR: Missing resource key: task_statuses_4 {"userId":1,"exception":"[object] (Exception(code: 0): Missing resource key: task_statuses_4 at /var/www/app/app/Jobs/Util/Import.php:1299)
#0 /var/www/app/app/Jobs/Util/Import.php(1160): App\\Jobs\\Util\\Import->transformId('task_statuses', '4')
#1 /var/www/app/app/Jobs/Util/Import.php(198): App\\Jobs\\Util\\Import->processTasks(Array)
#2 /var/www/app/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(36): App\\Jobs\\Util\\Import->handle()
#3 /var/www/app/vendor/laravel/framework/src/Illuminate/Container/Util.php(40): Illuminate\\Container\\BoundMethod::Illuminate\\Container\\{closure}()
#4 /var/www/app/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(93): Illuminate\\Container\\Util::unwrapIfClosure(Object(Closure))
#5 /var/www/app/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(37): Illuminate\\Container\\BoundMethod::callBoundMethod(Object(Illuminate\\Foundation\\Application), Array, Object(Closure))
#6 /var/www/app/vendor/laravel/framework/src/Illuminate/Container/Container.php(610): Illuminate\\Container\\BoundMethod::call(Object(Illuminate\\Foundation\\Application), Array, Array, NULL)
#7 /var/www/app/vendor/laravel/framework/src/Illuminate/Bus/Dispatcher.php(128): Illuminate\\Container\\Container->call(Array)
#8 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(128): Illuminate\\Bus\\Dispatcher->Illuminate\\Bus\\{closure}(Object(App\\Jobs\\Util\\Import))
#9 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}(Object(App\\Jobs\\Util\\Import))
#10 /var/www/app/vendor/laravel/framework/src/Illuminate/Bus/Dispatcher.php(132): Illuminate\\Pipeline\\Pipeline->then(Object(Closure))
#11 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Bus/Dispatchable.php(67): Illuminate\\Bus\\Dispatcher->dispatchNow(Object(App\\Jobs\\Util\\Import))
#12 /var/www/app/app/Jobs/Util/StartMigration.php(111): App\\Jobs\\Util\\Import::dispatchNow('/var/www/app/pu...', Object(App\\Models\\Company), Object(App\\Models\\User))
#13 /var/www/app/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(36): App\\Jobs\\Util\\StartMigration->handle()
#14 /var/www/app/vendor/laravel/framework/src/Illuminate/Container/Util.php(40): Illuminate\\Container\\BoundMethod::Illuminate\\Container\\{closure}()
#15 /var/www/app/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(93): Illuminate\\Container\\Util::unwrapIfClosure(Object(Closure))
#16 /var/www/app/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(37): Illuminate\\Container\\BoundMethod::callBoundMethod(Object(Illuminate\\Foundation\\Application), Array, Object(Closure))
#17 /var/www/app/vendor/laravel/framework/src/Illuminate/Container/Container.php(610): Illuminate\\Container\\BoundMethod::call(Object(Illuminate\\Foundation\\Application), Array, Array, NULL)
#18 /var/www/app/vendor/laravel/framework/src/Illuminate/Bus/Dispatcher.php(128): Illuminate\\Container\\Container->call(Array)
#19 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(128): Illuminate\\Bus\\Dispatcher->Illuminate\\Bus\\{closure}(Object(App\\Jobs\\Util\\StartMigration))
#20 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}(Object(App\\Jobs\\Util\\StartMigration))
#21 /var/www/app/vendor/laravel/framework/src/Illuminate/Bus/Dispatcher.php(132): Illuminate\\Pipeline\\Pipeline->then(Object(Closure))
#22 /var/www/app/vendor/laravel/framework/src/Illuminate/Queue/CallQueuedHandler.php(96): Illuminate\\Bus\\Dispatcher->dispatchNow(Object(App\\Jobs\\Util\\StartMigration), false)
#23 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(128): Illuminate\\Queue\\CallQueuedHandler->Illuminate\\Queue\\{closure}(Object(App\\Jobs\\Util\\StartMigration))
#24 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}(Object(App\\Jobs\\Util\\StartMigration))
#25 /var/www/app/vendor/laravel/framework/src/Illuminate/Queue/CallQueuedHandler.php(98): Illuminate\\Pipeline\\Pipeline->then(Object(Closure))
#26 /var/www/app/vendor/laravel/framework/src/Illuminate/Queue/CallQueuedHandler.php(67): Illuminate\\Queue\\CallQueuedHandler->dispatchThroughMiddleware(Object(Illuminate\\Queue\\Jobs\\DatabaseJob), Object(App\\Jobs\\Util\\StartMigration))
#27 /var/www/app/vendor/laravel/framework/src/Illuminate/Queue/Jobs/Job.php(98): Illuminate\\Queue\\CallQueuedHandler->call(Object(Illuminate\\Queue\\Jobs\\DatabaseJob), Array)
#28 /var/www/app/vendor/laravel/framework/src/Illuminate/Queue/Worker.php(406): Illuminate\\Queue\\Jobs\\Job->fire()
#29 /var/www/app/vendor/laravel/framework/src/Illuminate/Queue/Worker.php(356): Illuminate\\Queue\\Worker->process('database', Object(Illuminate\\Queue\\Jobs\\DatabaseJob), Object(Illuminate\\Queue\\WorkerOptions))
#30 /var/www/app/vendor/laravel/framework/src/Illuminate/Queue/Worker.php(158): Illuminate\\Queue\\Worker->runJob(Object(Illuminate\\Queue\\Jobs\\DatabaseJob), 'database', Object(Illuminate\\Queue\\WorkerOptions))
#31 /var/www/app/vendor/laravel/framework/src/Illuminate/Queue/Console/WorkCommand.php(116): Illuminate\\Queue\\Worker->daemon('database', 'default', Object(Illuminate\\Queue\\WorkerOptions))
#32 /var/www/app/vendor/laravel/framework/src/Illuminate/Queue/Console/WorkCommand.php(100): Illuminate\\Queue\\Console\\WorkCommand->runWorker('database', 'default')
#33 /var/www/app/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(36): Illuminate\\Queue\\Console\\WorkCommand->handle()
#34 /var/www/app/vendor/laravel/framework/src/Illuminate/Container/Util.php(40): Illuminate\\Container\\BoundMethod::Illuminate\\Container\\{closure}()
#35 /var/www/app/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(93): Illuminate\\Container\\Util::unwrapIfClosure(Object(Closure))
#36 /var/www/app/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(37): Illuminate\\Container\\BoundMethod::callBoundMethod(Object(Illuminate\\Foundation\\Application), Array, Object(Closure))
#37 /var/www/app/vendor/laravel/framework/src/Illuminate/Container/Container.php(610): Illuminate\\Container\\BoundMethod::call(Object(Illuminate\\Foundation\\Application), Array, Array, NULL)
#38 /var/www/app/vendor/laravel/framework/src/Illuminate/Console/Command.php(136): Illuminate\\Container\\Container->call(Array)
#39 /var/www/app/vendor/symfony/console/Command/Command.php(255): Illuminate\\Console\\Command->execute(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Illuminate\\Console\\OutputStyle))
#40 /var/www/app/vendor/laravel/framework/src/Illuminate/Console/Command.php(121): Symfony\\Component\\Console\\Command\\Command->run(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Illuminate\\Console\\OutputStyle))
#41 /var/www/app/vendor/symfony/console/Application.php(971): Illuminate\\Console\\Command->run(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))
#42 /var/www/app/vendor/symfony/console/Application.php(290): Symfony\\Component\\Console\\Application->doRunCommand(Object(Illuminate\\Queue\\Console\\WorkCommand), Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))
#43 /var/www/app/vendor/symfony/console/Application.php(166): Symfony\\Component\\Console\\Application->doRun(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))
#44 /var/www/app/vendor/laravel/framework/src/Illuminate/Console/Application.php(93): Symfony\\Component\\Console\\Application->run(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))
#45 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php(129): Illuminate\\Console\\Application->run(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))
#46 /var/www/app/artisan(37): Illuminate\\Foundation\\Console\\Kernel->handle(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))
#47 {main}
sasax
December 18, 2020, 10:09am
21
Should I have to remove from v4 task statuses made by me, before do migration?
