I have have a current installation of invoice ninja V5 …
In my current installation, i got some bug after some update ( Thread here : Column not found: 1054 Unknown column 'current_hours' and here : Column not found: 1054 Unknown column ‘current_hours’ · invoiceninja/invoiceninja · Discussion #10726 · GitHub ) …
It’s actually working but There’s still some weird stuff that i’m not sure if it’s normal Behavior of Invoice Ninja or if something else is still break in my installation …
BTW, my old server is due to change so i was thinking about doing a fresh installation of invoice Ninja and Import my data into it …
The Migration procedure a found out actually talk about simply do a MySQL DUMP and move the folder public/storage folder …
As i suspect some problem within my MySQL structures and wish to eliminate it, i would prefer to let Fresh invoice ninja install do his job of creating the structure and import Data into it …
So is there a way within invoice Ninja to export all my informations in a clean way or the best way would be to do an export from phpmyadmin without having the structure embed into the .sql file ???
