I’d like to edit an invoice template. Initially, I want to simply add the words “TAX INVOICE” to the invoice.
I am using the Playful template as the starting point, and wanted to add TAX INVOICE above the area where $invoiceDetails is displayed.
I’ve had a play around in the pdfmake playground, but it seems to use a slightly different way of making declarations (they are not, for instance, put into quotation marks).
I’ve been unable to figure out how to insert a simply line of text where I want it. I can get it into various other places, but not above the invoice details box.
I’ve tried in a few spots, and as with my own custom code attempts earlier, nowhere seems to have the desired effect. Obviously I am completely missing the point of how it works.
Where in there would I insert the code you’ve provided?
Also, any clues on what field $entityTaxType links to? Does that have “Tax Invoice” in it by default? I suspect it’s something I’ll need to change, yes?
Here is an example of what I am trying to achieve (a before and after)…
Actually, I see now that the code that came through by email had a bunch of codes not in the code above.
So… using the code above… adding it where you said HAS in fact placed TAX INVOICE somewhat in the location I was after.
Thanks.
I’ll now see if I can fiddle with the alignment and size. I’ll set up a new style for the size.
As for the alignment, if you have any tips, they would be very welcome.
Thanks. Got it positioned and sized more or less how I would like.
What I would like, ideally, is to have it included in the table column in which the rectangle with the $invoiceDetails inside of it appears; positioned above it, such that it pushes that rectangle and its contents ($invoiceDetails) down, and the “TAX INVOICE” text sits at the same top alignment as the logo.
Working on that now. I’ll let you know if I get stuck.
The way the design is constructed would make this difficult. You’d need to move the rectangle and $invoiceDetails into a stack and then include the label at the top.
