Hey, I’ve tried another image, but the problem still occurs.
After updating to 2.9.3 I can see it when I preview my invoice. The problem is the left margin. If left margin ml=30 on the following page ml=ml+ml.
On trello I saw, that invoiceNinja can create client IDs. But not when the self hosted? I have to manage it my own, don’t I?
Btw. Thanks for the german translation. But its not complete. Can I participate to translate?
I installed the newest version and have the problem as ever.
My workaround until Hillel solved the issue:
Header on the first page with the footer, on the following Pages footer only. But I am missing page-numbers @Hillel
How far is the solution process!?
Ah I see. Thank for the suggested workaround I will try it today.
Did you see that there is a new version 0.1.25 from the pdfmake framework.
In the last versions there were some performance improvements… Maybe it was helpful.
pretty good to know, that the issue is going to be solved soon, I hope =). I will try the workaround with a margin in my image. Thanks Hillel and thanks Stefan for your research!
