I tried tirelessly to upgrade from v4 to v5 to no avail and finally got frustrated and started new.
The issue I’m having now is first, the window title always shows undefined. For instance, when on the Dashboard screen, it shows undefined:Dashboard
Secondly, if I click around to the various links in the system (Invoices, Create new Client, Dashboard, etc…it works just fine and as expected) However, if I refresh the page, I get 404 errors.
The NGINX log shows:
x.x.x.x - - [05/Aug/2022:15:52:46 -0600] “GET /dashboard HTTP/1.1” 404 1832 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/103.0.0.0 Safari/537.36”
My NGINX config shows:
server {
server_name ninja.example.com;
root /var/www/ninja/public/;
charset utf-8;
client_max_body_size 20M;
location / {
if (!-e $request_filename) {
location = /robots.txt { access_log off; log_not_found off; }
access_log /var/log/nginx/invoiceninja.access.log;
error_log /var/log/nginx/invoiceninja.error.log;
location ~ \.php$ {
fastcgi_pass unix:/run/php/php8.0-fpm.sock;
fastcgi_index index.php;
include fastcgi_params;
fastcgi_param SCRIPT_NAME $fastcgi_script_name;
fastcgi_intercept_errors off;
fastcgi_buffer_size 16k;
fastcgi_buffers 4 16k;
location ~ /\.ht {
deny all;
sendfile off;
listen [::]:443 ssl ipv6only=on; # managed by Certbot
listen 443 ssl; # managed by Certbot
ssl_certificate /etc/letsencrypt/live/ninja.example.com/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/ninja.example.com/privkey.pem; # managed by Certbot
include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
server {
if ($host = ninja.example.com) {
return 301 https://$host$request_uri;
} # managed by Certbot
listen 80;
listen [::]:80;
return 404; # managed by Certbot
My APP_URL in the .env is correct
I have ran php artisan optimize, just to make sure everything is loaded.
I am not sure what else to inform you on but if I’m missing something, just ask.
