Thanks, the link ends in ‘/public/login’, if you setup the server web root to point to /public you can use ‘/login’ instead which should fix the iFrame problem.
Sorry, I don’t know another way to solve the problem you’re seeing.
Okay, I appreciate your help. Sorry for the confusion. Can you also remove the code from message #23572 above?
Thanks.
That worked. Thank you for your patience.
Awesome, glad to hear it!
