The TOTAL should include the VAT: 371,99 EUR
Surprisingly, everywhere else in InvoiceNinja, the totals are displayed correctly, but not at the generated PDFs.
I use my own template, that is made as a duplicate of the default one (Clean). Is this a known bug in v5.3.9-C59, or if not - how could I resolve this? Thanks.
Above the line items, it states correctly the Total amount that includes the taxes. Below the line item, it states Subtotals TWICE (950,00 HRK), but there is no trace of the real TOTAL that includes the taxes.
These are my settings in my local language (I’m not sure if I switch it to English whether my localization aka. “translated variables” will be remembered):
Why is totals_table-subtotal printed twice within the totals-table-right-side (screenshot above) and how could I hide/remove the last occurrence of it? Thank you.
Thanks Ben, I just sent you a PM here.
However, the storage/framework/laravel.log file seems obsolete (?) in your docs. Perhaps should be changed to storage/logs/laravel.log, since the former one does not exists on my server.
I just found another useful hint which may help to resolve this issue. There are 2 issues actually.
The first issue is that the following menu option is NOT visible in a local (translated) Desktop mode using the resolution of 1920x1080px when you just opened Invoice Fields tab, which is an obvious UX flaw/bug and imo should be resolved by scrolling the menu items on hover:
Settings > Invoice Design > Total Fields tab is NOT visible
All I had to do is to remove the Subtotal item at the bottom of the Total Fields, which I just did. Now I can see the issue is gone but only within the PDF PREVIEW mode (generated whilst adding Invoice items).
The second issue is that even if I modified the Total Fields items, the changes are still not reflected on the Downloaded PDF. The generated Total Fields items are still the same as per my screenshot on Oct 1:
I use PhantomJS as SaaS for generating PDFs. Perhaps a caching issue?
How could I enforce the modified settings in the Total Fields to be visible at the downloaded PDF?
