Hello, I bought now a VPS and set up a Domain.
I use SmarTTY to connect via SSH and have a File Browser.
Domain and Subdomain are connectet via DNS to my VPS IP 87. XX.XX.XX
The Subdomain is used for the InvoiceNinja
so i installed Nginx Proxy Manager
To find my ip adress of the other container i used
docker ps
docker inspect ContainerID of my NPM
“Gateway”: “172.18.0.1”,
“IPAddress”: “172.18.0.3”,
so for the ENV im using AppURL = https://rechnung.mydomain.at:8003/
for the docker-compose file there are 3 lines with
extra_hosts:
- "in5.localhost:192.168.0.124 " #host and ip
What should i input there?
"rechnung.mydomain.at:172.18.0.4 " #host and ip ?
must i activate the 443 Port there?
Thank you, Nico.
April 19, 2024, 1:12pm
Sorry, I’m not sure.
Note: you may need to add TRUSTED_PROXIES=* to the .env file.
The leading free source available online invoicing app for freelancers & businesses. Invoice, accept payments, track expenses, & time-tasks
Thank you and thx for the link
This is working so far
IN application vars
APP_URL=https://rechnung.domain.at (no 8003 here)
APP_KEY=base64:Z…
APP_DEBUG=false
REQUIRE_HTTPS=true
PHANTOMJS_PDF_GENERATION=false (Must be off)
PDF_GENERATOR=snappdf
TRUSTED_PROXIES=‘*’ (error if something is in)
QUEUE_CONNECTION=database
DB connection
DB_HOST=db
DB_PORT=3306
DB_DATABASE=ninja
DB_USERNAME=
DB_PASSWORD=
Create initial user
Default to these values if empty
IN_PASSWORD=changeme!
IN_USER_EMAIL=
IN_PASSWORD=
Mail options
MAIL_MAILER=smtp
MAIL_HOST=smtp.ionos.de
MAIL_PORT=587
MAIL_USERNAME=
MAIL_PASSWORD=
MAIL_ENCRYPTION=starttls
MAIL_FROM_ADDRESS=
MAIL_FROM_NAME=
MySQL
MYSQL_ROOT_PASSWORD=
MYSQL_USER=
MYSQL_PASSWORD=
MYSQL_DATABASE=ninja
V4 env vars
DB_STRICT=false
APP_CIPHER=AES-256-CBC
Without in5.localhost everything is crashing
version: ‘3.7’
services:
server:
image: nginx
restart: always
env_file: env
volumes:
# Vhost configuration
#- ./config/caddy/Caddyfile:/etc/caddy/Caddyfiledocker-com
- ./docker/app/public:/var/www/app/public:ro
depends_on:
- app
# Run webserver nginx on port 80
# Feel free to modify depending what port is already occupied
ports:
- “8003:80”
#- “4430:443”
networks:
- invoiceninja
extra_hosts:
- "in5.localhost:172.19.0.1 " #host and ip
app:
env_file: env
restart: always
volumes:
- ./config/php/php.ini:/usr/local/etc/php/php.ini
- ./config/php/php-cli.ini:/usr/local/etc/php/php-cli.ini
depends_on:
- db
networks:
- invoiceninja
extra_hosts:
db:
image: mysql:8
When running on ARM64 use MariaDB instead of MySQL
image: mariadb:10.4
For auto DB backups comment out image and use the build block below
build:
context: ./config/mysql
ports:
- "3305:3306"
restart: always
env_file: env
volumes:
- ./docker/mysql/data:/var/lib/mysql:rw,delegated
# remove comments for next 4 lines if you want auto sql backups
#- ./docker/mysql/bak:/backups:rw
#- ./config/mysql/backup-script:/etc/cron.daily/daily:ro
#- ./config/mysql/backup-script:/etc/cron.weekly/weekly:ro
#- ./config/mysql/backup-script:/etc/cron.monthly/monthly:ro
networks:
- invoiceninja
extra_hosts:
THIS IS ONLY A VALID CONFIGURATION FOR IN 4. DO NOT USE FOR IN 5.
cron:
image: invoiceninja/invoiceninja:alpine-4
volumes:
# - ./docker/app/public:/var/www/app/public:rw,delegated
# - ./docker/app/storage:/var/www/app/storage:rw,delegated
# - ./docker/app/public/logo:/var/www/app/public/logo:rw,delegated
entrypoint: |
/bin/sh -c 'sh -s <<EOF
trap “break;exit” SIGHUP SIGINT SIGTERM
sleep 300s
while /bin/true; do
./artisan ninja:send-invoices
./artisan ninja:send-reminders
sleep 1d
done
EOF’
networks:
- invoiceninja
networks:
invoiceninja:
This domain is working
but if i send a Invoice via Mail the customer gets a link with :8003 in it
then it wont connect to invoice ninja
Nginx Proxy Manager
April 20, 2024, 5:08pm
8
Glad to hear it, thanks for sharing the solution!
I had removed the :8003 from the env file
How could i stop this happen? You must reupload the Logo
Solved (Logo not Showing)
