invoicing task items summarize instead of details
Hi I am logging my time each day for each client
so on a day i can have multiple rows for clients
fe 08:00 - 10:00 task1 client1
10:00 - 12:00n task 2 client 2
13:00-16:00 task 1 client 1
when creating invoice for client a i only want to see the total for each different task
so client A
  • type A : 5 hours
now i see 2 lines for each records
is this possible ?
By default the app adds the time details, you can remove them in the invoice item description.
We don’t currently have a way to change the behavior, you’d need to self host and modify the code.
can this be a feature request ?
I think a lot of freelancers need this feature.
so option to sum all hours for a task
Sorry for next question`
how can we remove the start and end hour of a task in the invoice ?
The sum is shown in the ‘Hours’ column, I’m not sure about showing it twice instead of the details.
On an unrelated topic… what would you think about us adding a Kanban board to help manage tasks.
that’s a goog idea i use kanban in my development work in my TFS online dashboard.
Question now i see under description the start and end hour. How can i remove it from the description ?
You just need to manually edit the invoice line item details, if you click the textarea it will expand.
