Invoice with QR code that updates invoice status
I’m using the self-hosting version of Invoice Ninja for a few months now.
One of the things I’m looking for is a way to add QR codes on my invoices.
For now I see two solutions:
Solution 1
Modify the invoice template and add QR details like below:
{ "qr": "BCD\n001\n1\nSCT\nBIC WITHOUT WHITESPACES\nFULL NAME WITH SPACES\nIBAN WITHOUT WHITESPACES\nEUR$invoice.balanceAmount\n\n\n$entityType $invoice.invoiceNumber\n", "eccLevel": "M" }
This solutions seems to work partially.
The payment will be executed, but the invoice status will not be updated.
Is there a way to call a webhook to achieve this?
Or is there something that can be included in the qr code to make this work?
Solution 2
"qr" : "$paymentLink"
Unfortunately this doesn’t work at all.
I hoped this would create a QR code that would open the payment url.
For some reason this variable is not recognized.
The drawback of this solutions is that bankapps will not recognize this qr code and will confuse customers.
So I would prefere to use the first solution.
See below for the full template.
    "columns": [
        "image": "$accountLogo",
        "fit": [
          120,
          80
        "margin": [
          0,
          60,
          0,
          30
        "stack": "$clientDetails",
        "margin": [
          0,
          60,
          0,
          0
    "style": "invoiceLineItemsTable",
    "table": {
      "headerRows": 1,
      "widths": [
        "15%",
        "40%",
        "20%",
        "10%",
        "15%"
      "body": "$invoiceLineItems"
    "layout": {
      "hLineWidth": "$notFirst:.5",
      "vLineWidth": "$notFirstAndLastColumn:.5",
      "hLineColor": "#888888",
      "vLineColor": "#FFFFFF",
      "paddingLeft": "$amount:8",
      "paddingRight": "$amount:8",
      "paddingTop": "$amount:8",
      "paddingBottom": "$amount:8"
    "columns": [
      "$notesAndTerms",
        "table": {
          "widths": [
            "40%"
          "body": "$subtotalsWithoutBalance"
        "layout": {
          "hLineWidth": "$none",
          "vLineWidth": "$none",
          "paddingLeft": "$amount:34",
          "paddingTop": "$amount:4",
          "paddingBottom": "$amount:4"
    "columns": [
        "canvas": [
            "type": "rect",
            "x": 0,
            "y": 0,
            "w": 515,
            "h": 26,
            "r": 0,
            "lineWidth": 1,
            "color": "$secondaryColor:#403d3d"
        "width": 10,
        "margin": [
          0,
          10,
          0,
          0
        "text": "$balanceDueLabel",
        "style": "subtotalsBalanceDueLabel",
        "margin": [
          0,
          16,
          0,
          0
        "width": 370
        "text": "$balanceDue",
        "style": "subtotalsBalanceDue",
        "margin": [
          0,
          16,
          8,
          0
    "eccLevel": "M"
  "$signature",
    "stack": [
      "$invoiceDocuments"
    "style": "invoiceDocuments"
The app supports adding webhooks on Settings > API Tokens
I already found that setting.
But how do I trigger that webhook after someone has scanned the QR code:
The person who would scan this QR code will be redirected to their banking app and can make the payment.
However since there is no relationship between making that payment and calling the webhook, I will be required to check my bank account and update the invoice manually.
I’m using Mollie as payment gateway provider.
The only option I see is to use their API to create a payment (after my invoice in Invoice Ninja has been created), so that I can retrieve the QR code from them.
https://docs.mollie.com/guides/qr-codes
However this would require me to extend the functionality of Invoice Ninja to be able to do that I suppose.
Understood, maybe you can use the Invoice Ninja API?
I don’t see how using the Invoice Ninja API would help me on this one. Therefore I’m going to dive into the code and check how payment processing is being done right now. Hopefully extending this functionality isn’t a big effort. Nevertheless if I can get it working I will make a pull request.
I replied on another topic to get more information about how the author processes the invoice after payment: https://www.invoiceninja.com/forums/topic/epc-qr-code/
In theory if the payment gateway provides hooks you could use the API to update the app after the payment is made.
Does anybody know if there is going to be(or if someone is working on one) an upgraded version of the mollie payment driver?
Invoiceninja still uses the V1 from Mollie, the V2 is more flexible.
Sorry for not making a new thread, I don’t think I have the rights to open one.
