Hi, I experience slow response times as well. After enabling the Slow query log in Mysql, it looks like a bottle neck there. I use SnapPDF to make invoices, the server OS is CentOS 8 running PHP 7.4 with Apache. Small tasks like deleting an invoice will return in a couple seconds, while adding line items to an invoice could take over a minute.
Are there any ideas why some queries would take so long? Appreciate any help,
Ted
Not just related to PDF, all tasks are slow and related to Mysql as evident by the slow query log. I have other sites like Ninja4, Wordpress, Django that all make queries in the millisecond range. I have two Ninja5 instances installed on this server and they are both slow to respond thru Mysql.
Here is an example from the slow query log that is set to show queries over 10 sec. This query took 10.8 sec.
# Thread_id: 15957 Schema: russ_ninja5_2 QC_hit: No
# Query_time: 10.825493 Lock_time: 0.000094 Rows_sent: 0 Rows_examined: 1
# Rows_affected: 1 Bytes_sent: 52
use russ_ninja5_2;
SET timestamp=1624382881;
update clients set balance = ‘1’, clients.updated_at = ‘2021-06-22 17:27:50.275616’ where id = 6;
I think this simple query should not take so long, do you have suggestions for how to debug it? Thank you
On the topic of PDF, I thought SnapPDF was the preferred method? If not, which PDF generator is preferred?
