hi,
After I reach invoice number 100 /2023 now I have to edit each one after 100 number like:
100/2023_zVFWZ
Edit: every invoice have 100 number / 2023 _just Suffixes changed every time.
How can I solve that ?
Version: 5.3.29
hi,
100/2023_zVFWZ
Version: 5.3.29
You can check that the counter is correct on Settings > Generated Numbers.
It looks like you’re using a much older version of the app, I suggest upgrading to the latest version.
In settings:
number pattern: {$counter}/{$year}
Number counter: 1
It may help to change it to the correct number
