Is it possible to add a field up near the top somewhere for Invoice Title or Subject? Thanks!
You could add use a custom field and then add it to the PDF using a custom design.
Okay cool. I went to:
Settings > Invoice Settings > Custom Fields > Invoices
And added “Invoice Title” the first empty Invoice Field box and saved changes.
Then went to:
Settings > Invoice Design > Invoice Fields
And using the Invoice Fields dropdown, selected the newly created Invoice Title, and then dragged it to the correct position in the list… under the invoice number, and Saved changes.
Works great.
Thanks!
