Invoice template change
In the Invoice template, I want “Item” and “Description” of the product in the same column, Instead of placing in two different columns.
Description should append to the Item text only. How to do it ?
Thanks in advance.
@david is this possible now using TWIG or is it not yet supported?
@hillel
We are blocked on this one until the templating design/functionality decisions are finalized.
Hi David,
In which release can we expect this option?
Thanks,
