I have tasks that goes on continuously over months and I use the time tracker to keep track of the time spent on each task.
Is there a way to invoice each month just the time tracked on that month on all the tasks?
Thanks!!!
Andrea
Sorry, it isn’t currently supported. You’d need to create separate tasks for each month.
Ok, thanks for the answer.
Is there a quick way to move some time tracking that I’ve done this month to a new task? Maybe changing some fields directly on the db.
Andrea
Sorry, not that I’m aware of.
We strongly advise against manually changing the database.
Doh!
