I am having problem all my invoice was blank and unable to save after i change my site to https:
Are there any errors in the browser console and/or webserver logs?
Hi, it was unable to save.
http://prntscr.com/h21xbg
when in https mode, i was unable to see any client, invoice…etc
http://prntscr.com/h21xtw
Please check for details in the browser console and server/application error logs.
attach please find the error console from chrome
where to get this server/application error logs
Can you check that the APP_URL value in the .env file starts with ‘https’
The server log location will depend on the server you’re using, for Apache it’s usually /var/log/apache2/error.log, the application logs are in storage/logs/laravel-error.log
yes, it start with https in .env
i am using cpanel
In this capture (https://prnt.sc/h258mo) why are both .com and .com.mv listed, are you using a proxy?
Based on that capture it looks like they are using CloudFlare… This will require extra work on the cloudflare part to assure SSL is transferred over.
