I’ve had a problem and had to delete one invoice, since then the automatic numbering is off.
it’s ahead 1 invoice all the time and i need to manually adjust it , when i set the correct number in the settings and save it, it still doesnt go 1 invoice back in time…
Can you check on the Invoice Settings page (/company/advanced_settings/invoice_settings) that the value for the invoice number counter matches the value you want for the next invoice number.
I tried that to set it from for example from 12 to 11 again but when creating a new invoice it went back to 12 again skipping 11
I fixed it yesterdayevening by removing the faulty invoice not showing in the system from the database and this fixed my error ! good thing the database is very clear
