Was not generated.
I will monitor the new recurring invoice and let’s see.
Now the status in waiting so should be set correctly let’s see if will be sent, if not i will update this discussion.
Thank you for the support.
Hi, thank you for your message! I use PHP 7.3 as i keep always software updated.
I have just one doubt and is the recurring invoice was not created correctly.
I will monitor the new created where now the status is pending so it’s correct.
Your welcome. I went through the same situation, as you described it, with the recurring statements before i figured it was the php version. If you have a testing environment you can set the job to fire every few minutes so do don’t have to wait for long.
Great! My apologies for missing that detail. I’ve updated my self hosting copy, tested the recurring invoice with PHP 7.2, then updated to PHP 7.3 and tested again. The invoice emails where successfully received and the PDFs where successfully generated.
@peopleinside I withdraw my previous suggestion, because your running the latest version. Like Hillel recommended, you need to get the output from the cron jobs.
Hi Hillel, hope you are well and you enjoy this Christmas time. Don’t know if you celebrate this.
I have manually sent an recurring invoice because was not automatically sent.
The invoice was sent at 6 of the month because also if i set to send the first day was not send maybe because customer has no email? I don’t have to send by email to costumer, i have to see generated invoice in the system.
I was not able to generate the invoice without a valid email address on the customer profile, this is bad for me. I put mine email for be able to send and activate the recurring invoice.
This caused the invoice was not sent automatically the first of the month as i set so i need force the send at 6 of the month. After done this i removed the email address from the customer as they should not receive by email.
Now i don’t know if also the next invoice will be not generated because of this anyway is scheduled for the 6 of the next month, I need correct this date to the first of the month.
In the recurring invoice i see sent on 6 and will send next on 6. How can i edit in the database will be sent on 6 to will be sent on 1?
Hope in the future you can add the possibility to change this scheduled date from the interface without have to stop the recurring invoice and generate another one.
Hope also you will insert an option to be not forced to send invoice to the customer who don’t want have sent by email but i need have in the web interface.
I still have recurring invoice not automated created. The cron is active, no errors.
Your software gives to me issues on recurring invoice. I have to send manually every month.
Hi Hillel, it’s not easy.
Since i moved from a different invoice system the only issue that found in your software is how generation of invoice works.
I update your software with Softaculous script manager, my HP is updated 7.3 as for Apache and my server.
Again this month the system has not generated the invoice and i need send manually.
In the past the system was not sending on correct date and as now i cannot correct i sent yesterday the invoice and i need is sent every first day of the month… need stop the recurring invoice and create another.
Also i don’t like the system send email when i need to generate manually the invoice and customer must have an email address or system give an error. I don’t have to send invoice to the customer, I’m not into business i need manage invoice by myself.
I don’t know why is so hard have recurring invoice working.
Mine is just a feedback, i think i will still have issue on this.
