When I check the log it says a directory does not exist.
This should probably adressed with an update?
I am running IN on my Synology in Docker, installed with the tutorial of Marius Hosting
TIA
TIA
Are you running the latest version?
I did update recently in container manager
Checked in Portainer, version 5.6.14
That’s a much older version, the latest version is v5.7.25
I used to see updates in container manager or portainer but not now…
Sorry, I’m not familiar with portainer.
The latest version is available on docker hub:
I’ll check with Marius…
worked with the following:
Now to solve the issue just change the following line in your docker stack compose:
image: invoiceninja/invoiceninja:latest
with
image: invoiceninja/invoiceninja:5.7.22
then update the stack in Portainer.
Glad to hear it’s working, thanks for sharing the solution!
