Hi Friends,
Is invoice ninja now a 64 bit only application? When I attempt to install 5.7.57, even 5.7.59, I can’t run the upgrade DB process as composer says it has 64 bit dependencies. I’ve been running on a raspberry pi, but see this is now not going to be possible any longer.
** running upgrade
Composer detected issues in your platform:
Your Composer dependencies require a 64-bit build of PHP.
PHP Fatal error: Composer detected issues in your platform: Your Composer dependencies require a 64-bit build of PHP. in /var/www/5.7.59/vendor/composer/platform_check.php on line 28
Is this the official stance?
Thanks,
Dave
