system
April 3, 2017, 4:56am
1
Hi
I don’t know what I have edited or changed but the invoice link no longer works.
I clicked a link in a mail to view an invoice and got the following error:
Sorry, the page you are looking for could not be found.
Here’s the link (With the URL blocked out of-course)
https://billing.XXXXXXXXXX.com/client?XXXXXXXXXX
April 3, 2017, 5:00am
I’m not sure, it’s important APP_URL is correct in the .env file for the link to work.
The link format doesn’t look right to me, it should be http://ninja.dev/client/dashboard/XXXXXX
system
April 3, 2017, 5:06am
3
Apologies, this is self hosted Hillel, I forgot to mention.
April 3, 2017, 5:08am
4
I realize, but your link is /client?XXXXXXXXXX whereas mine is /client/dashboard/XXXXXX. Seems like it may be related.
system
April 3, 2017, 5:10am
5
I fixed it. I set a new sub domain and hey presto.
ovizii
June 12, 2019, 11:42pm
7
Having a similar problem with Invoice Ninja - v4.5.13 run via Docker.
In the email notification to myself about an invoice that was sent out there is a button to view the invoice: https://pasteboard.co/IjcHxtd.png
Clicking that button leads to:
https://mydomain.tld//invoices/50 which gices “Sorry, the page you are looking for could not be found.”
if I remove one of the 2 // => https://mydomain.tld/invoices/50 I get redirected to https://mydomain.tld/login which seems to be the desired outcome.
where does this // come from? any way to fix it?
June 13, 2019, 12:19am
8
Maybe there is a slash at the end of the APP_URL setting in the .env file?
ovizii
June 13, 2019, 1:10am
9
yes there was a trailing slash and I have removed it now but shouldn’t the web server be able to deal with a double slash? most do.
ovizii
June 13, 2019, 3:03am
11
sorry but I can’t confirm yet as I have to wait for another invoice to be sent out and then check the link inside the notification email.
