Invoice footer is not showing, I can see it in the configuration section but not in invoices, any suggestions? thank you.
If you go into Settings > Invoice Design, under the Invoice Options tab there will be selectors to show the header and footer on either the last page, or on all pages.
Maybe the footer is being cut off, does changing the design help?
Hi Titanfail, I have selected it to show on all pages, not working. Thank you.
Hi Hillel Coren, I have tried all the designs and still not showing, thank you.
When I add 3 or more items to an invoice then the footer will show up, but with 2 or less items won’t.
That’s odd… does changing the design have any affect?
