Hi everybody!
I use Invoice Ninja v5.4.9-C87.
Steps to reproduce the problem:
Settings (Advanced settings) > Custom Fields > Invoices
. Create a custom multiline invoice field. - Fill created multiline field with multiline content.
- In rendered invoice carriage return symbols are transformed into spaces.
Fill the custom field with:
First line
Second line
And I’ll see in the rendered invoice:
First line Second line
Is it correct behavior?
PS I can put <br>
tag in the end of each line to fix the issue, but I think it pollutes my text with HTML symbols.
UPD I have “Enable PDF Markdown” enabled in Settings > Account Management
, but it does not work in the custom field. Is it correct behavior?
