Invoce variable after update to 4.3.1 error
after update to 4.3.1 i changed the invoice variable, but the var “$account.address1” does not work. The all other are ok. There are no errors in log files.
Thanks and regards
the var “$client.address1” does not work too.
This is a bug, we’ll include a fix with our next release.
You can apply the patch by updating this file:
https://github.com/invoiceninja/invoiceninja/blob/master/public/built.js
unfortunately it did not help:
cd /var/www/ninja/public
mv built.js built.js_old
wget https://github.com/invoiceninja/invoiceninja/blob/master/public/built.js
This vars does not work:
$account.custom_value1
$account.work_email
$client.address1
$account.address1
Maybe you need to force refresh the page to clear the browser cache?
Imade
I’m not sure…
I was able to reproduce the bug with address1 however the fix works for me.
The other two variables should be $account.customValue1 and $account.workEmail
FYI… I’ve checked in a change to support workEmail or work_email
The variable “$account.workEmail” works now.
The other three does not.
System Info:
cat /etc/redhat-release
CentOS Linux release 7.4.1708 (Core)
php -v
PHP 7.0.29 (cli) (built: Mar 28 2018 07:46:18) ( NTS )
apachectl -v
Server version: Apache/2.4.6 (CentOS)
Sorry, I can’t replicate the problem.
Thank you for your support.
I’ll go back to version 4.2.2.
